Author Topic: New member - Plymouth 1929 Two Door Sedan  (Read 3902 times)
jjohn
  • 1929U 2dr sedan
« on: October 04, 2012, 11:57:07 PM »
Hi
We just bought a 1929 Plymouth with engine number U4026 in Sweden.
Can not find the chassis number of the vehicle body probably gone.
Glad to find this forum!
1930
Re: New member - Plymouth 1929 Two Door Sedan
« Reply #1 on: October 05, 2012, 01:34:25 AM »
Very nice car, I do hope you plan to maintain it as an original car
Jason Anderson
« Reply #2 on: October 05, 2012, 12:44:30 PM »
The carís serial number is embossed in the emblem on the dash board.
Fedco Serial Number Code
W P C H R Y S L E D
0 1 2 3 4 5 6 7 8 9
Nice car,  Chet...
A good link for info:     http://www.ply33.com/
  • 29U 4dr Sedan #Y089WE
« Reply #3 on: October 05, 2012, 05:02:47 PM »
Welcome!  Great to see a 2-door Sedan.  As a recent member myself, you will find a wealth of info in past discussions.
jjohn
  • 1929U 2dr sedan
« Reply #4 on: October 06, 2012, 11:11:19 PM »
Hi the plan is to make to a original car.
The car was found in a barn where it has stood for over 25 years. Before then, it has been run in Sweden little unclear when.
/jonas
« Last Edit: October 06, 2012, 11:17:20 PM by jjohn »
kimmc
« Reply #5 on: October 11, 2012, 01:58:41 AM »
Hey Jonas.  Looks like a nice car.  The body looks good...I can't see any dents.  I am working on restoring my '29 Plymouth coupe.  I am posting my adventures on the forum; it started out under the title "I need some advice".  Lots of helpful folks on this forum.  You will always get a reply from someone who has encountered a similar problem.  Keep us posted on your progress.  Everyone likes to look at pictures!  Good luck.  Kim
jjohn
  • 1929U 2dr sedan
« Reply #6 on: October 12, 2012, 06:55:57 PM »
Hi,
The radiator on the car (1929) has the part number: PA 8-14-28,
is this correct for this model?
« Last Edit: October 12, 2012, 07:07:26 PM by jjohn »
kimmc
« Reply #7 on: October 12, 2012, 07:34:25 PM »
First, I'm not an expert, so maybe someone else can tell you about the part number.  Here's what I know.  The radiator shell looks correct; the Plymouth badge is missing (it goes in the hole on front near the top) but maybe you have removed that.  The radiator core is not correct.  The '29s had a "honey comb" core radiator.  I have one still in its original crate (pic attached and close-up of the core).  Sorry, it's not for sale.  These radiators are difficult to find and expensive.  The '29s had no grill so the exposed radiator core was what you saw.  I have heard that some shops can take an old core and cut about a 1" slice off the face and use that as a "false front" with a modern radiator core behind.  This gives the look of an original radiator.  Vintage radiators are expensive...I was quoted $2400 to build a new reproduction honey comb radiator using my old top and bottom tanks.  If you find a good used '29 radiator for less than $1000, I would probably buy it.  Others may have different ideas.  Good luck with your project...it is fun.  Kim
jjohn
  • 1929U 2dr sedan
« Reply #8 on: October 12, 2012, 07:43:19 PM »
The radiator looks not the same at the top left and right
/jonas
« Last Edit: October 12, 2012, 07:45:53 PM by jjohn »
kimmc
« Reply #9 on: October 12, 2012, 09:40:59 PM »
Looks to me like original '29 tanks were put on a modern core.  The original "honey comb" core was probably corroded and leaked.  I hear that they are very difficult to repair.  I guess it is cheaper to put in a modern radiator core.  If this radiator works and doesn't leak, maybe just paint the core black and use it for a while; spend the money on some other part of the car.  That would give you some time to research and consider your options.  The old parts do turn up from time to time...it's kind of surprising what you can find.  Kim
