Author Topic: Spark Plug Wires  (Read 1427 times)
Spark Plug Wires
« on: January 16, 2014, 01:09:39 AM »
All:
Any recommendations on replacement spark plug wires for our cars, whether a set from a supplier/vendor, or a "kit" to make my own?  I haven't looked around too much lately and just want to know what you've used in the past or recently.  I'd like to find authentic or close to authentic as possible.
Thanks!
  • Canadian
Re: Spark Plug Wires
« Reply #1 on: January 16, 2014, 06:41:15 PM »
The wires were originally black laquered cloth with rubber insides and braided "solid" wire. The sparkplug connectors were 90 degree open with no boots. I use the better modern ozone proof neoprene braided wire type. I use a screw type in-line resistor on the coil wire. This cuts down on "motorboating" in your radio and any around you. "Popping" in your radio and transmitting it about a square block around your car was quite common with these old cars. I don't recommend cutting up up-market modern silicone wires ,to make your own,as it's also most impossible to make a good connection. I know this doesn't help with where you would buy them as I make my own from stuff bought at fleamarkets.
« Reply #2 on: January 16, 2014, 07:02:25 PM »
I think I bought mine from "Then & Now".  Look fine and with the right lengths.
 http://www.maritimedragracing.com/then_and_now_automotive_part.htm
« Reply #3 on: January 17, 2014, 12:33:28 AM »
Thanks for the input...no radio to worry about on mine.  The ones on there look to be laid out like the originals would be (90 degree attachment to the plug, no boot, etc.) but they are not the originals.  The are a black wire by (Packard aftermarket).
Also, what is the correct color?  Black?  I thought I read somewhere that an "oak" color (a dark orange) is correct for "early" cars.  How about the size...7mm or 9mm?  Again, I saw something about 9mm for "early" cars as well, but I think that would be to thick to fit through the steel wire loom.
Thoughts on this?  What are your guys using?
« Last Edit: January 17, 2014, 01:05:19 AM by racertb »
