Author Topic: carburetor for 29 U & 30 U  (Read 2556 times)
seasand
« on: September 15, 2015, 07:31:04 PM »
Does anyone know what make carburetor was used on the 29 U? Also what carburetor was used on the 30 U when they switched from vacuum tank to a fuel pump? Was it the same?
George
Re: carburetor for 29 U & 30 U
« Reply #1 on: September 15, 2015, 08:05:00 PM »
29U was a Carter RT-08.  Cast in lower base.  Don't know 30U.  RT on your left, carter DRT-08 on right.    frank
« Reply #2 on: September 15, 2015, 09:44:17 PM »
I think Frank is correct. The RT-08 on the 28, 29 and early 30U. The DRT-08 (much easier to fine) used on the late 30-U and 31 and 32.
Just my guess.
Gary R.
seasand
« Reply #3 on: September 16, 2015, 08:47:15 PM »
So the DRT-08 was used in conjunction with fuel pumps. Does that sound correct?
  • Canadian
« Reply #4 on: September 19, 2015, 04:17:24 PM »
Boy frank those bowls are REALLY dirty. They should very shiny brass. BTW the same bowl was used on Chevs in those years. I know because the Plymouth bowls split from frezzing up here and we all had to find new ones when we were restoring ours.
« Reply #5 on: September 20, 2015, 02:52:51 PM »
You're right Old Man, They are dirty!  For some reason I have never been able to get a good seal, bowl to body, or maybe the float level adjusted incorrectly.  Going along fine with no leaks and suddenly it will start.  Have to be in the float/needle valve, but what produces the inconsistency?  Debris in the valve seat I suppose.
Have to laugh.  When Dave first started his engine, he cleaned his carb and reassembled without bowl gasket.  I confidently told him it was sure to leak - ha!  Not a drop!
  • Canadian
« Reply #6 on: September 21, 2015, 03:00:23 PM »
Original cars I found had a red rubber sealing ring between bowl and carb. Exactly the same as my wife's sealing jars! I used cork (that I can still buy in sheets of different thicknesses )from my local car parts place.
« Reply #7 on: September 22, 2015, 07:06:52 PM »
Paper gaskets are supplied with today's re-build kits, so that is what I use.  Had to clean carb yesterday and put a bit of polish to the bowl.
