Author Topic: Early plymouth keys  (Read 1725 times)
1930
Early plymouth keys
« on: January 27, 2013, 02:57:47 PM »
Hey guys, I am hoping that someone here can tell me what was the shape of the ORIGINAL key heads that would have operated your early Plymouth's.
For instance did the ignition originally use a hex shaped key head, maybe the door locks used round and so what did your spare tire locks use or maybe spare tire locks were not issued with your Plymouth's if your cars had side-mounts.
By early Plymouth I am interested mainly 28-30 or so although I would love to hear what any year used right on up until the mid thirties. Thanks
  • Canadian
Re: Early plymouth keys
« Reply #1 on: January 27, 2013, 07:02:30 PM »
This is an original '29U ignition key. I found 2 other keys from the 30s. One is an original '33 Plymouth door key and the other is an 'original' '35 Dodge truck ignition key. Not sure about the Dodge key's heritage. And I seem to remember my'31 PA had these same size and shape keys. It would appear early Chrysler Corp. keys were round originally?
« Last Edit: January 27, 2013, 07:29:10 PM by Old Man »
1930
« Reply #2 on: January 27, 2013, 08:25:27 PM »
Thanks, cannot read the key, wont let me enlarge, is it Basco? The 29 I mean
  • Canadian
« Reply #3 on: January 27, 2013, 11:12:50 PM »
The '29 has a capital 'D' inside a diamond on one side and H700 on the other. The '33 says U122. The 'U' being kind of a Chrysler give away. The '35 Dodge I think is a replacement for a lost key at some time. But you would think the locksmith would replace it with the same 'kind'/'shape' etc? So I assume it is a good copy of the original. I remember all the GMs I've ever had or driven from 1958 on (My Dad's '58 Olds Super 88) had the 'hexagonal' shape to the 'handle' you mention. I remember it being a kind of GM trait.
« Last Edit: January 27, 2013, 11:22:19 PM by Old Man »
1930
« Reply #4 on: January 28, 2013, 03:31:15 AM »
Thanks, just to verify, Plymouth did use the N.E coil behind ignition lock assy unit 28/29 maybe 30 correct. I think it was sometime in 30 that they went with the Delco?
  • Canadian
« Reply #5 on: January 28, 2013, 03:05:28 PM »
'28,'29 and 30U had the ignition lock/switch built into the bottom of the coil. '31 PA had the 1st Chrysler company style coil mounted on and through the firewall with an armored cable going from the dash switch to the rear of the coil. Sorry I don't know my manufacturers.
1930
« Reply #6 on: January 29, 2013, 12:09:34 AM »
Thanks again, I am sure it was N.E
