Thank you guys,
I tried everything with the ignition, so I’m not that sure about the ignition problem anymore.
I think it's time to pay more attention to the carburetor. It's a Carter BB-1 - 245SD ( 2 3/8” Stud Centers – Throttle Bore 1 7/16” ) and I'm trying to get another Carb just to see if the problems are more on the fuel side.
Ian, from your Post (October 15, 2013, 03:18:42 AM) do you know which carburetor are on your car? Is it a Stromberg?
I’m asking because it may be easier to convert to a downdraft carb, as to look for a updraft carb in my area. Searched the forum/net and made me a little list, seems this carburetors eventually working on the PA:
Updraft carburetors:
Tillotson "JR4 A" or „Model X“
Zenith-1
Carters (OEM D209S) bb1, 4A3,
Downdraft carburetors: (seems that everyone needs modification to make the stud holes line up)
Carter WO 146-249
Stromberg: EXV2 (not sure about them)
I’m sure you guys know some more, I would very appreciate if you can post them??
Thanks again and happy Easter,
Roland
PS: Chet, I did a complete restoration on the Engine, so it should be mechanically okay.
