Author Topic: 29 Sedan Roof comments welcomed  (Read 1564 times)
moparfreak77
Re: 29 Sedan Roof comments welcomed
« Reply #15 on: September 04, 2018, 03:52:28 AM »
Does the dome light come on with the doors open or only if you hit the switch?
« Reply #16 on: September 04, 2018, 04:27:06 PM »
The stock wiring diagram doesn't show a door switch.
Geoff57
  • Fourth Gear
« Reply #17 on: September 17, 2018, 01:19:18 AM »
CrazyDave,
Your information on how to do the roof is great. 'Chester Brzostowski' put me onto this topic. Best I could find was  Roof Insert Kit 35-36 plymouth & Dodge 4 door sedan. at http://houseoftops.com/roof-inserts/ .
Could you please advise what/how do you progress after installing all the bows eg.
hessian
tar compound
how thick
tricks and hints
I have original left and right main front to back roof pine rafters with no obvious pre-attachments. There is also other differences in brackets and mounting on the Australian assembled 1929 Q's.
Regards
Geoff Davidson, Canberra Australia  gsdavidson@grapevine.net.au
« Reply #18 on: September 18, 2018, 03:04:59 AM »
Geoff57,
I have not repaired my roof yet, the work posted has all been Chet. I have just taken a few pictures and measurements.
See his details here > http://www.1948plymouth.info/1929/Work_files/2017/08312017.htm
Here > http://www.1948plymouth.info/1929/Work_files/2017/09132017.htm
and the main thread here > http://www.1948plymouth.info/28Q29U/index.php?topic=1102.90
If there is a specific original part that I can measure or take a picture of let me know.
Good luck!
