Author Topic: 29 Build Thread - Part 3  (Read 2590 times)
« on: January 30, 2020, 10:12:38 AM »
Year 4 Hopefully the conclusion of this project.
Just a recap for January.  If weather permits, work continues  :)
http://www.1948plymouth.info/1929/Work_files/2020/Jan-2020.htm
Re: 29 Build Thread - Part 3
« Reply #1 on: January 30, 2020, 02:01:27 PM »
Great progress.  You are about a year ahead of me in my restoration so your well documented progress is very helpful.
« Reply #2 on: January 31, 2020, 12:44:26 AM »
Superlative, Chet!  A reminder to have a good ground to your lamp housings.   frank
« Reply #3 on: January 31, 2020, 08:49:27 AM »
Thanks Frank I got it covered. I run additional ground wire for all lamps unless impeccable continuity to ground.    :)
Russ, Glad you see some value in my compulsive rambling.
« Reply #4 on: January 31, 2020, 02:29:20 PM »
It's certainly coming together!
« Reply #5 on: February 14, 2020, 10:27:07 AM »
Details, details.
Making slow but steady progress  :)
Click the link below for the blow by blow.
http://www.1948plymouth.info/1929/Work_files/2020/02142020.htm
« Reply #6 on: February 14, 2020, 08:49:22 PM »
Very creative Chet!  May have to borrow your idea.
Marc28plym
« Reply #7 on: February 15, 2020, 06:00:39 AM »
Looking good!
« Reply #8 on: February 15, 2020, 09:15:05 AM »
Hi Frank
I assume you mean the vacuum valve. Had to do something.  I need to pass a one time inspection and the windshield wiper has to be functional. The only other solution would be electrical and that just wouldn’t be right.  Actually the exterior on/off valve would possibly be OK for inspection but still not correct for the car.  The aquarium air valve fits the 3 ‘F’ test. Form - close, Fit - acceptable, Function - right on. Can’t beat the price.
Cheers, Chet
« Reply #9 on: February 22, 2020, 05:39:51 PM »
Starting to look like a car again.
http://www.1948plymouth.info/1929/Work_files/2020/02222020.htm
Marc28plym
« Reply #10 on: February 23, 2020, 10:40:48 AM »
She's looking great!
« Reply #11 on: February 26, 2020, 09:39:17 AM »
On the home stretch!
« Reply #12 on: February 26, 2020, 11:58:07 AM »
Ted, I’m not sure about the home stretch but certainly rounding the last lap.
« Reply #13 on: February 28, 2020, 06:09:12 PM »
Chet, lookin' real good!  I'm sure you'll put this extra day to good use.
« Reply #14 on: March 10, 2020, 05:56:24 PM »
Almost finished with all the Mechanical Work.
Making good progress  :)
Many Thanks go out to Rich, < 29plycoup > for a headlamp plug to finish off my lights.
Quite a job getting the lights setup properly.  Especially with 91 year-old parts.
http://www.1948plymouth.info/1929/Work_files/2020/03102020.htm
